Hi there,
I have just bought a Mixtrack Pro II off EBay and it is acting strangely. I'm not sure if it is a dodgy controller, or if there is an issue with Virtual DJ. For example the browser does not scroll down the file list, but cycles through the sidelist tabs. The left hand Sync button appears to be flashing to the beat of the song. This does not happen in Serato.
Any ideas? Also can I export the mapping script?
geposted Thu 24 Dec 20 @ 9:28 pm
With your mouse click on a song in browser the use the browser on controller.
geposted Sat 26 Dec 20 @ 2:49 am
Hi Phil, yes I can do that, but I don't need to with my Mixtrack Pro, just this Pro II. And only the Load A button loads a track. The Load B button does nothing. Again, I don't have this problem with the Mixtrack Pro. I tried downloading the mapping from the Numark website as well as the factory default one in VDJ.
geposted Mon 28 Dec 20 @ 5:11 pm
Maybe you got a bad controller. IDK
geposted Mon 28 Dec 20 @ 7:06 pm
