Is there a way I can jump to a saved cue point, with the use of a hot cue, while still in a loop, without making the point where I jumped to via the hot cue into a loop itself? I'm trying to eliminate having to turn off the saved loop prior to going to the new que point and I don't want the cue point location where I go to be loop. Thanks.
geposted Mon 28 Dec 20 @ 6:54 pm
Can be done, might have to create your own button or custom pads for it, or download one that works that way...
The action loop_exit & hot_cue X will do... where X is the numbered cue point
geposted Mon 28 Dec 20 @ 8:40 pm
Thank you!
geposted Mon 28 Dec 20 @ 8:46 pm
