In Starter and Essentials Skin Mode I can quickly change between crossfading effects. I can't find this routine on other skins. Is it possible ton lay this function or menu on a Custom Button ?
Thanks a Lot
Thanks a Lot
geposted Tue 05 Jan 21 @ 5:21 pm
Sure it is.
DIY Tip; open the config >> mapping window, click the eye dropper [script learn] button, click the skin element you want to learn the script of.
Learn it there, apply it to your custom button.
geposted Tue 05 Jan 21 @ 5:25 pm
Just map a custom button with the action effect_mixfx
If you set the custom button name field with the text query you'll also see the name of the current selected mix fx on the button
Or you can add them to the pads, available in Extensions:
https://devs.virtualdj.com/plugins/index.html?addonid=81259
geposted Tue 05 Jan 21 @ 7:39 pm
Hey guys,
thanks a lot. That was really helpful !!!!
geposted Tue 05 Jan 21 @ 9:21 pm
