There seems to be a missing feature...
I currently have 41 sample banks, but I don't need all of them all the time.
Some are audio, some are video, some are still images - all for different purposes. The problem is, they're all listed, all the time.
If I'm doing something that only requires the use of one or two banks, I shouldn't have to click through all 41 to get to the ones I need. We need a way to organise them, like sub banks or the ability to hide banks until we need them.
There's an option to create a sub folder, but I don't seem to be able to move anything into it (from within VDJ).
[edit] Something else worth mentioning. The sample playback mode is global.
Unfortunately the mode you choose is not suited to everything you might play. For example I might want stutter mode for vocal drops, but when I play a looping video clip, having stutter mode selected means I can't stop the clip unless I change modes.
Please allow the mode to be set for individual samples rather than everything.
geposted Tue 12 Jan 21 @ 12:27 pm
It's indeed not possible to use subfolders, but you can move the order in the browser and this order should also be reflected in the drop-down and next/previous sample bank actions.
geposted Tue 12 Jan 21 @ 12:36 pm
Would anyone else like to see some kind of sample bank organisation?
Some way of selecting which banks we want for a particular job, rather than just one great big list that we have to reorder manually for different purposes.
Also the other thing I mentioned, about the playback mode being global. I think it would improve the sampler to allow the mode to be set per sample (or even per bank would be better than global).
geposted Wed 03 Feb 21 @ 1:42 pm
I remember years ago where there was a plug-in that sorted out sample banks for you would be great if we had that now because I too found myself running into this problem .....
geposted Wed 03 Feb 21 @ 9:29 pm
