Is it possible to change/modify the first 3 pad keys on the DDJ- SB3? It appears that the last one and the shift ones are the only ones that can be changed . I attached a pic.
. Thanks!
. Thanks!
geposted Sat 16 Jan 21 @ 8:12 pm
You can change all of those, to pads you prefer...
See here: https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#controller
geposted Sat 16 Jan 21 @ 8:51 pm
geposted Sat 16 Jan 21 @ 9:26 pm
ah yes, true . some pads encoded in hardware only, so not assignable to new functions
geposted Sat 16 Jan 21 @ 9:52 pm
Thanks!..:)
geposted Sat 16 Jan 21 @ 9:58 pm
