: Computers with Intel 11th gen Core i-series CPU's can result in a failed audio or MIDI connection with primary hardware has anyone found a solution for this yet
geposted Thu 21 Jan 21 @ 1:47 am
When I read your message, I suspected you might be quoting it - and yes you are.
It's been posted by Serato here and there are further details on that page.
@Tony - if you are using one of these 11th gen CPUs, then you need to give details.
What is the make and model of the computer that has a problem?
geposted Thu 21 Jan 21 @ 9:18 am
