Hi, trying out VDJ, checking if I could move over from Serato.
I find that the Sync function in Serato is more useful for my use than the Sync in VDJ. As I have seen, many options in VDJ are configurable. Is there a way to modify the Sync to be (more) Serato-like?
I'm mostly playing Open Format, and thus mixing various genres and BPMs, so I can't really use the Auto Match BPM and Auto Sync on Play (this also syncs the BPM).
Thanks!
Thanks!
geposted Sun 24 Jan 21 @ 1:04 pm
Yes, VDJ syncs the bpm if paused, or syncs bpm and beat grid if the track is playing - but it doesn't lock the sync
Serato (2 types of sync) locks when it syncs - either "in time" (bpm and beat grid) or just locks
If you want to do that in VDJ you use:
pitch_lock (just locks)
beatlock (locks in time)
geposted Sun 24 Jan 21 @ 3:09 pm
Thanks, I'll try these out!
geposted Mon 25 Jan 21 @ 7:07 pm
