newest update is giving me inactive interface. tracks can be loaded and played but it appears as if nothing is happening in vdj.
Running a new G7 7700 so not a hardware issue.
geposted Wed 27 Jan 21 @ 1:18 am
Pc or mac?
geposted Wed 27 Jan 21 @ 5:22 am
PC
geposted Fri 29 Jan 21 @ 8:40 pm
if waveform dont move and nothing happens, perhaps the sound card is already taken.
Look in VDJ sound settings if there are any error there
geposted Fri 29 Jan 21 @ 8:43 pm
I am also having issues with the latest update. When I load a track in ANY deck it virtually (excuse the pun) disappears.
I can still play the song but NO WAVEFORM in the deck or at the top in the waveform area.
Any ideas what would cause this?
geposted Sat 30 Jan 21 @ 4:18 am
Try this update, just download and run the installer to have the latest :
https://virtualdj.com/download/pc/6281 (Windows)
https://virtualdj.com/download/mac/6281 (Windows)
Should fix the waveform ;-)
geposted Sat 30 Jan 21 @ 9:59 am
I have not had these problems but I noticed that in the live skin, when you press the loop button, it does not appear on the screen (as it normally did) to make it appear you have to reduce or increase the loop beats. Can anyone confirm?
Thank you
Thank you
geposted Sat 30 Jan 21 @ 12:19 pm
Rune, hit the update problems solved!
This got me to looking , i was noticing that on the last build it was trying to update to this build 6281 but would time out about half way through. after doing so it would then download optimized version for my hardware. I'm not sure what exactly it was doing considering it wouldn't update , it felt like and update loop.
geposted Sat 30 Jan 21 @ 3:23 pm
The additional big update that comes after startup is improved support for Nvidia cards for stems.
Just try again, and let that part finish.
geposted Sat 30 Jan 21 @ 9:10 pm
Yes I noticed the same.
geposted Sun 31 Jan 21 @ 12:20 am
I have the same problem: build 6334.1768...
Is there a fix?
geposted Wed 24 Mar 21 @ 4:34 am
Which problem? There are at least three listed in this thread.
geposted Wed 24 Mar 21 @ 9:56 am
