scratch bank not working correctly on v8.6-64 b6280. Nothing can be saved or loaded. Can you fix it with next update,
thanks
thanks
geposted Wed 27 Jan 21 @ 11:54 am
What is not working correctly exactly?
geposted Wed 27 Jan 21 @ 12:01 pm
nothing can be saved or loaded.
geposted Wed 27 Jan 21 @ 12:23 pm
maybe it's only because scratchbank_load scratchbank_assign scratchbank_load_to_deck are not documented
by the way ... buttons caption localized or resized do not fit the buttons
geposted Wed 27 Jan 21 @ 12:35 pm
https://www.youtube.com/watch?v=6EKIHfvzheY
Like this it's not working?
geposted Wed 27 Jan 21 @ 12:41 pm
No, the but missing part not show in the video:
exitting VDJ everything disappears and have to be done again next time
it looks like banks are working as session only
in fact every time VDJ starts scratch banks editor is empty
geposted Wed 27 Jan 21 @ 12:56 pm
I just discovered the "export zipped scratch bank" that created VirtualDJ\ScratchBanks folder with an xml file
maybe initial folder was not existing (not created during the update process)
but not any import yet
geposted Wed 27 Jan 21 @ 1:03 pm
Works fine here. As soon as I drop a file on a pad it creates the ScratchBanks folder and saves the scratch bank.
Restarting vdj then reads it correctly as well.
geposted Wed 27 Jan 21 @ 1:43 pm
For me the folder didn't create initially
I only saw it after I rightclicked a bank
after what the bank itself appears twice (maybe once for xml and once for zip)
there is no indicator (i.e. [edit] like with skins) to make a difference
geposted Wed 27 Jan 21 @ 1:57 pm
I deleted ScratchBanks folder in virtualdj. İts working now
geposted Wed 27 Jan 21 @ 2:44 pm
Another issue is : a new "scratch banks editor" opens everytime the button is pressed (many instances)
geposted Wed 27 Jan 21 @ 3:35 pm
