How do these people get the bpm from?
Most Of The Time they are off or just wrong.
What Do You Think?
What Do You Think?
geposted Sun 31 Jan 21 @ 5:43 pm
Depends a bit on the music you are playing.. .
By your nickname, perhaps its disco music that is often recorded by live musicians and otherwise dont have a steady bpm to be used?
And you can also try using the variable bpm function in the BPM editor to see if that gets things better (for songs that have different "parts" with different bpm)
https://virtualdj.com/manuals/virtualdj/editors/bpmeditor.html
geposted Sun 31 Jan 21 @ 6:42 pm
Thanks Rune. But I'm Talking about ON LINE BPM search.
geposted Sun 31 Jan 21 @ 6:45 pm
You can search online but doubt it helps.. Variable bpm is variable bpm.
And live musicians dont play perfectly...
The BPM in VirtualDJ is not from some catalog or online, but rather from analyzing the song
Have an example of a song perhaps?
https://songbpm.com/ | https://getsongbpm.com/tempo | https://tunebat.com/Search | https://www.bpmdatabase.com/music/search/ etc etc etc..
Can give the above a quick test, I doubt it will help much and only be an average ish bpm same to VDJ
Better off trying the BPM editor or Tap the beat in VirtualDJ most likely.
Try that also ;-)
Try that also ;-)
geposted Sun 31 Jan 21 @ 7:00 pm
I think what he means is that he's using one of the built in online streaming services, and is searching for a track by entering a BPM.
@philadisco you should try and give more information when you post. Explain what you're doing (or trying to do).
geposted Sun 31 Jan 21 @ 7:05 pm
When I'm Not sure of a songs bpm like jimmy cliff -I Can See Clearly Now.
I check on line to see what it might be by google and see what I Can fine to compare too.
Hope this Helps to understand my question.
geposted Sun 31 Jan 21 @ 7:12 pm
Why bother? You can tap it into VDJ.
I also have an app (liveBPM) on my phone that gives a readout within seconds.
geposted Sun 31 Jan 21 @ 8:05 pm
philadisco wrote :
songs bpm like jimmy cliff -I Can See Clearly Now. .
Seems pretty accurate in VirtualDJ.... at 120 bpm
Might "drift" a little if its a live recorded songs and not steady beats, if thats what you mean.
And is same BPM you would find on online sites...
https://getsongbpm.com/song/i-can-see-clearly-now/2Oy8j
https://songbpm.com/@jimmy-cliff/i-can-see-clearly-now
https://tunebat.com/Info/I-Can-See-Clearly-Now-Jimmy-Cliff/0NK9yClWapVnb6yewGWOSg
etc etc etc
geposted Sun 31 Jan 21 @ 8:18 pm
Screen Shot 2021-01-31 at 8.51.43 PM
https://virtualdj.com/img/329124/73247/Screen%20Shot%202021-01-31%20at%208.51.43%20PM.png
geposted Mon 01 Feb 21 @ 1:53 am
I am not that problem
Sometimes it's not a good recording, you have to multiply the BPM by x2 manually in the Tag editor
see picture
see picture
geposted Mon 01 Feb 21 @ 8:32 am
