Hi there.
I need a script for a button to habe the automix Playlist play only on certain decks.
For example i have 4 decks and need to have the automix Playlist to start on all 4 decks. And a button to start the automix Playlist on deck 3 and 4.
How can i do that.. Regards
geposted Mon 01 Feb 21 @ 8:50 am
just use deck x before the automix action.
So,,
deck 1 automix
deck 2 automix
etc
So,,
deck 1 automix
deck 2 automix
etc
geposted Mon 01 Feb 21 @ 9:31 am
Thanks so the script for more than one deck will be like deck 3 automix & deck 4 automix so the automix will be dual deck on deck 3 and 4
geposted Tue 02 Feb 21 @ 2:36 pm
So there is a way to have automix work on 4 decks and play one right after the other in sequence?
geposted Tue 08 Jun 21 @ 5:18 am
