Is it possible to use 2 webcams? If so, how do I switch back and forth between the 2 cameras?
geposted Mon 01 Feb 21 @ 5:48 pm
camera plugin have a webcam selector in its own GUI
(open it with little gear right of plugin name in popup)
it is slider #2
can be map to a custom button
it is slider #2
geposted Mon 01 Feb 21 @ 5:56 pm
Yes, and if you go to the settings for the camera plugin and click the 'more' button, a new window will open where you can choose your cameras and select how VDJ switches between them.
geposted Mon 01 Feb 21 @ 5:59 pm
Where do I find the camera settings? This is how I have it now.
geposted Mon 01 Feb 21 @ 6:07 pm
Nicotux told you in post #2
The VDJ manual is here https://virtualdj.com/manuals/virtualdj.html
geposted Mon 01 Feb 21 @ 6:21 pm
Alright fella, thank you! I figured it out!
geposted Mon 01 Feb 21 @ 6:33 pm
