Hi all,
i used to use virtual dj around 5 years ago with a Numark controller, and on there there used to be 'beatgrid' that used to work on a pad on my controller, I am trying out the new virtual dj and i just cannot seem to find 'beatgrid' ANYWHERE !
I am a bit of a noob at setting up controllers and editing keys/pads/buttons so please bear with me, but the controller is all in and working fine with effects etc no problem, but if possible i would just like the old beatgrid function back and set on one of my controllers pads, is beatgrid still on the new virtualdj but am just missing it somewhere ?
any help or guidance would most appreciated :-)
Thanks
Thanks
geposted Thu 04 Feb 21 @ 8:32 pm
Where have you looked? It's an effect, so look at the list of effects and you'll see it.
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
geposted Thu 04 Feb 21 @ 8:40 pm
Beat Grid is an internal Audio fx that needs to be specifically activated
Make sure you have installed it from setting -> extentions / effects / Audio Fx
geposted Thu 04 Feb 21 @ 8:43 pm
Brilliant :-) got it
Thanks all and keep safe ;-)
geposted Thu 04 Feb 21 @ 9:45 pm
