I used to have a shorcut setup so that if I had say a track on deck 1 that is 124 bpm and the other is 128 bpm I could hit the shortcut and the 124 bpm track would smoothly rise in increments to match the 128 bpm track without a sudden jump ready for the 128 bpm track to be mixed in without a pitch change. Can anyone tell me the command to do this again? Thanks.
geposted Fri 05 Feb 21 @ 12:52 pm
map any controller button or keyboard button to -> deck X pitch_reset
replace x with the deck number you want to use it for
geposted Fri 05 Feb 21 @ 12:58 pm
