It is probably something I am overlooking; but I am finding IDJPOOL entries in my search results even when I have the option for online catalogs turned off
geposted Sat 06 Feb 21 @ 7:02 pm
you can simply disable them from search bar options (little cog right of bar)
uncheck "search online catalogs" or choose "only use online catalogs when no local results"
geposted Sat 06 Feb 21 @ 7:39 pm
If you've searched for and streamed that track before, then it will have been added to your database.
geposted Sat 06 Feb 21 @ 9:24 pm
yes, i.e. from remixes sideview tab which can also use iDJPool
geposted Sat 06 Feb 21 @ 9:38 pm
