On my iPhone/iPad I use an app called DJ where in automix you can (1) determine the length of the fade (I like 30 seconds of cross fade), and (2) set it to match all BPM's to one standard, i.e. everything will run at 125 or 128 etc (you can set this yourself). Are these things possible in Virtual DJ's Automix? I haven't been able to find these settings. Thanks from a newbie!
geposted Sat 06 Feb 21 @ 11:16 pm
Hello and welcome here.
You should consider to read the manual ;)
Set it as you want..
geposted Sun 07 Feb 21 @ 7:02 am
Thank you! I was following the video steps and that was not explained on the automix video. But thank you!!!
geposted Sun 07 Feb 21 @ 3:37 pm
