Hello
Does anybody know if it is possible to change the mapper on the VU meters so that when the PFL Buttons on both decks are not active the VU meters are showing the master Output levels and When i press any of the PFL buttons the VU meters display the Individual Channel Levels for Decks A/B
geposted Mon 08 Feb 21 @ 5:35 pm
And if PFL is enabled on one of the Decks only, what do you want the other one to display ? The Other Deck (with PFL off) or nothing ?
Try mapping VUMETER as ..
and let me know if thats how you need it to work
device_side 'left' ? deck left pfl ? deck left get_level : deck right pfl ? nothing : deck master get_vu_meter_left : deck right pfl ? deck right get_level : deck left pfl ? nothing : deck master get_vu_meter_right
geposted Mon 08 Feb 21 @ 6:18 pm
yeah if one of the PFL buttons is enabled then i want the VU meters to display both Channel Level outputs and if the PFL is not on the i would like it to display the Master Output Level
Hope thats makes Sense :)
geposted Mon 08 Feb 21 @ 6:39 pm
Also on an unrelated note not sure if you know this but do you know if there will be any future updates to the skin builder and the skin builder extractor?
geposted Mon 08 Feb 21 @ 6:45 pm
then try this ...
device_side 'left' ? deck left pfl ? deck left get_level : deck right pfl ? deck left get_level : deck master get_vu_meter_left : deck right pfl ? deck right get_level : deck left pfl ? deck right get_level : deck master get_vu_meter_right
geposted Mon 08 Feb 21 @ 7:09 pm
Perfect That works perfectly very well thankyou
geposted Mon 08 Feb 21 @ 8:55 pm
