Hi, I hope someone can help. I just got a new laptop (it exceeds what virtual dj requires as far as op system and memory) and installed VDJ 2021. My Mixtrack Pro (version 1) doesn't seem to be recognized by the new VDJ software.
I've been using version 7 for years and the Mixtrack worked just fine. I've tried everything I know to resolve this but to no avail. Does anyone know if VDJ no longer supports the first version of Mixtrack Pro? As far as the website shows it's still supported. Thanks!!
geposted Tue 09 Feb 21 @ 12:41 am
Yes, support. I checked.
geposted Wed 10 Feb 21 @ 3:23 pm
Should work fine.
Perhaps bad usb cable or something?
Its plug & play with VirtualDJ
https://virtualdj.com/manuals/hardware/numark/mixtrackpro/setup.html
geposted Wed 10 Feb 21 @ 7:26 pm
