For some strange reason this mapping on both the apc 40 is reversed of every other fader up is off and down is on. Im confused.
line_fader_ master is the slider can anyone else check the apc 40, it works fine on the apc 20
geposted Thu 11 Feb 21 @ 5:26 pm
Not sure why, if its hardware or mapper..
But can easily be "fixed" in the script you are using by prepending param_invert
param_invert & effect_slider "audioonlyvisualisation" 2
geposted Thu 11 Feb 21 @ 6:25 pm
worked perfect.... thanks . I was driving me crazy
geposted Wed 03 Mar 21 @ 1:31 am
