Attempting to create a button to clone a deck
I created this mapping:
which causes the "while_pressed" to become a toggle function,
in that the button has to be pushed a second time to stop the dump action, instead of just releasing the button.
the
works perfectly alone, working only when the button is pressed.
and these
both work, so it's NOT the conditional construction that causes that the "while_pressed" not to work
Seems that the doubleclick removes the "while_pressed" action.
I could not find anything about interactions between these types of temporal, button pushes.
Are there any rules to use when coding, the order, do's and don'ts etc.
And how would one script, 2 different resulting actions from one button (without using the shift function)?
PS
Similiarly:
The use of "holding" below also created unexpected results
I can understand why the above would cause problems
would have thought this one had a chance of working
* I know "holding" is different then "while_pressed" , just trying to learn how these work together.
doubleclick ? clone_from_deck : dump while_pressed
the
dump while_pressed
and these
rightdeck ? nothing : reverse while_pressed
letfdeck ? reverse while_pressed : nothing
PS
Similiarly:
holding ? reverse : doubleclick ? clone_from_deck : nothing
doubleclick ? clone_from_deck : holding ? reverse : nothing
geposted Fri 12 Feb 21 @ 12:06 pm
they don't, use one or the other, never both.
geposted Fri 12 Feb 21 @ 5:21 pm
