I've tried multiple ways to turn off the leds or switch to flash in the settings. At best it turns off for 5 seconds and turns back to the default demo color cycling fade mode. Running latest version vdj, Win 10. I tried unplugging the controller after setting and restarting and various combinations but without any luck. Also tried switching usb ports. I'm kind of stumped. Does anyone have any ideas?
Thanks
Thanks
geposted Sun 14 Feb 21 @ 7:18 am
Are you using the Hercules sound card in Audio setup ?
If so , do you also get audio drops?
You may suffer from brief usb disconnections. Try a different usb cable.
Also try to enable createMidilog from vdj options and see if the generated log report.txt in /documents/virtualdj folder logs any disconnection info
geposted Sun 14 Feb 21 @ 11:49 am
I had bought a new usb cable for the Starlight but I tried 2 other new ones as well. No luck. I don't get audio drops when I use the inbuilt sound card. I enabled the midilog but don't see any disconnect mentions. I see some freeze messagings but I don't know what they mean.
geposted Tue 16 Feb 21 @ 12:04 pm
No issue here. Have you installed drivers ? https://support.hercules.com/en/product/djcontrolstarlight-en/
geposted Wed 17 Feb 21 @ 1:32 am
This page of the online manual explains how to manage the RGB back-lighting from within VDJ:
https://virtualdj.com/manuals/hardware/hercules/starlight/lights.html
But since you are not using the Pro version, I'm not sure if this feature will be available to you.
geposted Wed 17 Feb 21 @ 7:03 pm
The Lightmode selection is changed in recent Builds and now controlled from the VirtualDJ Settings->OPTIONS tab (edited manual page above).
Make sure you are using the factory default mapping for StarLight as custom mappings based on previous lightmode selection may not be affected from the new setrting.
geposted Wed 17 Feb 21 @ 7:21 pm
