read a few tut's on vdj 6,7,8 but in 2021 (8.5) dropping vsts into
C:\Users\user\Documents\VirtualDJ\Plugins64\SoundEffect
or
C:\Users\user\Documents\VirtualDJ\Plugins32\SoundEffect
doesn't populate them under the effects dropdown? Was support for this dropped?
or
geposted Thu 18 Feb 21 @ 12:16 am
it works, vst2, maybe restart vdj
geposted Thu 18 Feb 21 @ 12:18 am
one tut said I could use camelcrusher. Which I installed from here
https://www.audiopluginsforfree.com/camelcrusher/
I only tried the x64 though. Only copied the dll into the 64 folder
geposted Thu 18 Feb 21 @ 12:31 am
nop not only the dll, it needs siome external datas
install it with the installer in \Documents\VirtualDJ\Plugins64\SoundEffect
or
copy the dll to Documents\VirtualDJ\Plugins64\SoundEffect
create a link to ProgramData\Camel Audio\CamelCrusherData with the name "CamelCrusherData" in the folder you install the dll
or
geposted Thu 18 Feb 21 @ 4:40 am
no dice
https://imgur.com/a/nrtXKQb
geposted Fri 19 Feb 21 @ 1:59 am
@ThistleKnot I have not tried to install CamelCrusher, but it should appear in the FX Effects drop down.
You show the Padpages Drop down in your photo. (since it is NOT a Padpage, would not appear there)
Check the FX effects drop down. I am interested if its there.
geposted Fri 19 Feb 21 @ 2:44 am
I have CamelCrusher installed :
https://imgur.com/a/DjYxamg
(this is a custom skin, not an old VDJ version)
as IIDEEJAYII said : you are showing pad pages not effect selection
and all your other VST won't show : they are vst3 as VDJ only supports VST but NOT VST3
geposted Fri 19 Feb 21 @ 3:25 am
youre right ideaman
I was looking under pads and not effects (effects area button on the left in vdj2021)
geposted Fri 19 Feb 21 @ 2:58 pm
so... dll's work
what about vst's?
what about vst's?
geposted Fri 19 Feb 21 @ 3:45 pm
vsts are contained as .dll files.
geposted Fri 19 Feb 21 @ 4:17 pm
can you clarify. have folders for fl plugins that only list .vst3's
geposted Fri 19 Feb 21 @ 5:08 pm
5 posts earlier : "VDJ only supports VST but NOT VST3"
geposted Fri 19 Feb 21 @ 5:21 pm
thanks
frustrating. all the latest plugins don't have backports to earlier vsts
geposted Sat 20 Feb 21 @ 2:15 pm
which ones ?
CamelCrusher is a vst
helm have both
mbandpass have both
mcomb have both
helm have both
mbandpass have both
mcomb have both
geposted Sat 20 Feb 21 @ 2:56 pm
