Topic: 2 Virtual Folder issues
1. When you do a search to remove certain files from a virtual folder for example, all the files containing clean. After you do the folder search and highlight all, there is no option to "remove from virtual folder". The only option is to "remove". When you click "remove" the files go away but are still in the folder when you remove the search criteria.
2. When you nest folders, you cannot change the hierarchy of the folders in the nest. They only nest each other instead of showing the solid line where you can move them up or down.
geposted Thu 18 Feb 21 @ 5:13 pm
1) it looks like it remove only from search result
2) in fact "in Theory" you can because left side and right side of the folder name are used fot that
move into, move under
but in reality this is : do anything (move or duplicate or remove) and finally crash & recover
nested virtual folders are not a good idea
(i tested some crash when identified maybe a crash report was send)
I love using Virtual Folders, and use them a lot, and can be tricky at times.
See this thread https://virtualdj.com/forums/237216/VirtualDJ_Technical_Support/Help__Moving_a_Folder__to_make_it_a_Subfolder_.html?search=virtual%20folder&page=1.45
1) Would so much love to have an added feature: A way to see which Virtual Folders contain a selected track. That Each Virtual Folder would become BOLD or a Different COLOR (or some other way to quickly know which Virtual Folders, contain a selected file, in the browser.
There are many reasons this would be great.
If that was possible, one would then know which Virtual Folders that track was in and be able to remove it from the Virtual Folder(s) (by opening that Virtual Folder, R clicking and selecting "Remove from this Virtual Folder" for that track)
2) You can reorder the Nested Virtual Folders (Virtual Sub Folders) , by carefully, grabbing the Name and dragging them up/down. This only works for Virtual Sub-Folders.
See video of moving Deep House, Virtual Folder inside of the House, Virtual Folder.
https://gyazo.com/5c802027cfbb6eff2d766476dc2a1532
One cannot Move Virtual Folders that are, First level down from "Local Music" into an existing Virtual Subfolder or move it so it becomes a Virtual Sub-Folder.
The workaround: create a new Virtual Sub-Folder and copy all the contents to that Sub-Folder and Delete the old (original) folder.
Any news about this one ?
sub-folders can't reorder between sub-folders, or top level folder
left side and right side goes on not working in this case
(adding "Hashtag" entry in "Ma Bibliothèque" in a way to keep in sync with "MyLibrary")
