Where do i set the sample rate, all my audio chain is 48 apart from this setting at 44.1
geposted Sat 20 Feb 21 @ 4:03 pm
Did you check the asio control panel?
geposted Sat 20 Feb 21 @ 4:04 pm
Other than buffer nothing I can change there
geposted Sat 20 Feb 21 @ 4:11 pm
You could try the samplerate setting in options in virtualdj then, but there's a chance it doesn't support 48khz then.
Anyways, unless you recorded your music yourself, most of your music would be 44khz anyway no?
geposted Sat 20 Feb 21 @ 5:10 pm
user guide1.1 wrote :
USB Audio/MIDI Interface Sampling Rate 44.1 kHz
http://cdn.inmusicbrands.com/denondj/MC7000/MC7000-UserGuide-v1.1.pdf
geposted Sat 20 Feb 21 @ 5:33 pm
