Forum: Addons
Topic: DDJ-SB3 (2021)
geposted Sun 21 Feb 21 @ 5:34 pm
I believe its missing the shift button.
most skins are missing a shift button
either the controller have it, the keyboard have it, the mouse can't use it
only specialized touch screen skin may have the possibility to use it
you can add one as custom_button in "A2" panel
note all existing shift are working with this skin
hi
is there another skin for ddj sb3.
You can use any skin with any controller.
Which skin would be better to use for the DDJ SB2? The skin for the SB or the skin for the SB3? If anyone has used any and can give hints/tips please. Thank you in advance.
The default skin, either pro performance or essentials, or any skin you like. There is no such thing as 'best skin' all skins work with all hardware, it's all preference.
