wedding theme shadertoy? hearts, wedding rings, love,better together etc.?
geposted Wed 24 Feb 21 @ 3:57 am
Just look at ShaderToy https://www.shadertoy.com/
Might not be a whole lot of shaders in that theme, but should at least be some
Not sure how suitable shaders are in a wedding, but depends on age group and setting
You can find a lot of Wedding themed video loops that you can use in the VirtualDJ sampler that might be better
Example of usage, with combo of Shader + Text. And you can find some nice transparent "wedding frame" photos if you search on Google, to theme it even more. Just add those to the VirtualDJ Sampler to overlay on top. Just an ultra quick example in video below, can find much nicer ;-) and by that make the shader a bit more wedding-like perhaps..
Just test and play around and see if you find something that works for you ;-)
Just some quick ones from searches (but I have not tested all if they all work in VDJ but most should)
https://www.shadertoy.com/view/Xdc3Wr | view on shadertoy | copy link
https://www.shadertoy.com/view/WttBRl | view on shadertoy | copy link
https://www.shadertoy.com/view/MdKGzK | view on shadertoy | copy link
https://www.shadertoy.com/view/4dlGD7 | view on shadertoy | copy link
https://www.shadertoy.com/view/WdjSWm | view on shadertoy | copy link
https://www.shadertoy.com/view/3lBSRm | view on shadertoy | copy link
https://www.shadertoy.com/view/4lSXzR | view on shadertoy | copy link
https://www.shadertoy.com/view/4tjcz3 | view on shadertoy | copy link
https://www.shadertoy.com/view/XsfGRn | view on shadertoy | copy link
https://www.shadertoy.com/view/ll23Rd | view on shadertoy | copy link
https://www.shadertoy.com/view/XdcyW8 | view on shadertoy | copy link
https://www.shadertoy.com/view/4sccWr | view on shadertoy | copy link
https://www.shadertoy.com/view/lsd3D2 | view on shadertoy | copy link
https://www.shadertoy.com/view/MdfcRs | view on shadertoy | copy link
https://www.shadertoy.com/view/3ll3zr | view on shadertoy | copy link
https://www.shadertoy.com/view/3tKSWV | view on shadertoy | copy link
https://www.shadertoy.com/view/wsSXWR | view on shadertoy | copy link
https://www.shadertoy.com/view/4lfSz7 | view on shadertoy | copy link
https://www.shadertoy.com/view/lsK3RV | view on shadertoy | copy link
https://www.shadertoy.com/view/wt2GWK | view on shadertoy | copy link
https://www.shadertoy.com/view/tsySWW | view on shadertoy | copy link
https://www.shadertoy.com/view/tl3XRM | view on shadertoy | copy link
https://www.shadertoy.com/view/MltyRr | view on shadertoy | copy link
https://www.shadertoy.com/view/XsKBWD | view on shadertoy | copy link
https://www.shadertoy.com/view/WsSGzz | view on shadertoy | copy link
https://www.shadertoy.com/view/tt3XWX | view on shadertoy | copy link
https://www.shadertoy.com/view/3sSGRh | view on shadertoy | copy link
https://www.shadertoy.com/view/4dVXRd | view on shadertoy | copy link
https://www.shadertoy.com/view/WtjSD3 | view on shadertoy | copy link geposted Wed 24 Feb 21 @ 11:41 am
