los vídeos se traban y el cpu se va a ful .que debo hacer para resolver el problema , uso una dell 2021 tiene 2 de ram . como me pueden ayudar colegas dj
geposted Sun 28 Feb 21 @ 7:33 pm
As usual.... stop Dell panel
all update installed (including drivers)
and mathEngine disabled (no stem)
2Gb ram ... dell 2021 ?? bought in 2021 but may be pretty old
more info about CPU and GPU specifications needed for better help
geposted Sun 28 Feb 21 @ 8:10 pm
Try update all drivers, specially for graphic card.
And you can also try videoUseDXVA to "yes" in VirtualDJ settings (but should be on by default).
That being said, its normal that the CPU goes 100% during loading of a new song.
And with stems this can take a few seconds.... .
If you dont use stems, you can always set mathengine to disabled in settings, alternatively precomputeStems to "only use precomputed" and generate stems before you make your mix ;-)
geposted Sun 28 Feb 21 @ 8:49 pm
