Broadcast Setting is set to 1920x1080@6000,192
do i have change something there as well? and if so, what?
in vdj i can only change skin, video, and video record settings to 60 fps
cam was on 60 fps
cam was on 60 fps
geposted Fri 30 Apr 21 @ 1:02 pm
so, i just tested it at another Computer with 8.5 b6418 and broadcast to twitch.
no 60 fps at the stream. do i have to set something special in the options?
can someone else test if this will work with 60fps broadcast?
geposted Sat 01 May 21 @ 2:15 pm
From the change log:
"-Recording and broadcasting video fps can be customized (for broadcast at 60 fps, custom format is "1280x720x60@3500,128he" for example)"
So for your format, it should be changed to 1920x1080x60@6000,192
geposted Sat 01 May 21 @ 2:37 pm
Ahh thank you.. that works now! :)
geposted Sat 01 May 21 @ 2:52 pm
hello, sorry to bring this up again...
have a question... if i wanna stream to twitch when i use 720p@60fps it works all the time well and twitch is working with 720p@60fps.
when i try it in 1080p@60 fps some times twitch says its only 1080p@30 or 1080p@48fps and such things...
is this a virtual dj issue, a twitch issue or a problem at my side? is someone out there who can check this out?
if i use obs 1080p@60 its works but i still go directly from virtual dj...
thank you!
thank you!
geposted Tue 15 Feb 22 @ 8:07 am
