I use Deezer for my playlist five of my folders are showing empty how do I resolve this problem I made sure that the side bar music karaoke and Videos are not checked what should I do to fix this problem
geposted Sat 06 Mar 21 @ 3:55 pm
Do you mean all your folders, or just 5 out of many folders?
Aka, is none of them showing content, or only those few not showing?
If its not all folders empty, do those 5 have any thing particular about them? like being content of a different type ? For example not regular playlists but "liked songs" or "favorited" or having different type of audio (karaoke etc)
And are they much much larger than the other playlist?
Anything with those 5 that makes them different than the rest?
geposted Sat 06 Mar 21 @ 4:04 pm
I have two folders that I can open the other three are showing empty. Also the like and favorite folders is showing empty as well
geposted Sat 06 Mar 21 @ 4:35 pm
One folder has about 293 songs one folder has about 995 songs and the other one has about 900 songs as well
geposted Sat 06 Mar 21 @ 4:38 pm
I’ve never had an issue if I had over 1000 songs then it will show 1000 but that’s not the case this time
geposted Sat 06 Mar 21 @ 4:39 pm
Same problem here.Some playlists are showing empty in VDJ.Anyone worked out a fix ?
geposted Tue 09 Mar 21 @ 5:22 pm
