The problem is on vdj's end, and they know it. They need to fix it. The broadcasting on the dj's end is fine. The problem is with the player that vdj uses for your listeners to access your broadcast. It has a range of isp, format, kbs and multiple listener issiues. It is simply no good. This really needs to be corrected soon.
geposted Thu 11 Mar 21 @ 7:04 am
There really is no VDJ end on most of the broadcasting options
If you use option 1 you are communicating directly with a platform like Twitch ot Youtube
If you use option 3 you are communicating directly with a radio server
If you use option 2 your listeners are communicating directly with your laptop, which is acting as the server. The VDJ link is really just a pointer
... I personally don't recommend using option 2, because most people's network will only be able to handle very few listeners, and they may get dropouts if you have a regular consumer level internet
geposted Thu 11 Mar 21 @ 7:32 am
