Hi- am I able to add the vocal stem function to the custom button? Right now it’s on my pad but I use the pad for my cues.
If yes can you tell me how and what the script would be. I need a script to add the vocal stem and to add the instrumental stem. Thxs!
geposted Tue 16 Mar 21 @ 1:05 am
For vocals I guess you want to isolate vocal only (aka "accapella")
If so : stem_pad isolate 'vocal'
and for "instrumental stem", i guess you mean everything else, aka without vocal?
if so, just stem_pad 'vocal' (turns vocal on/off, leaving the instrumental when off)
geposted Tue 16 Mar 21 @ 1:13 am
Thx you! Will give it a try.
geposted Tue 16 Mar 21 @ 1:37 am
Would I go through the custom button editor? Not quite sure where to do this script. New to this.
geposted Tue 16 Mar 21 @ 1:40 am
I got it to work!! Been searching internet and found nothing. Thxs for responding and helping so quickly. Much appreciated.
geposted Tue 16 Mar 21 @ 1:45 am
