Since I have updated to 2021 my echo feature is not working correctly. Sort of sounds like filter rather than a strong echo. Do you know if there is a fix for this? Sorry if this has already been asked, just didn't see it anywhere.
geposted Sat 20 Mar 21 @ 8:25 pm
look at the fx gui, it has h&lp filter dials
geposted Sat 20 Mar 21 @ 9:14 pm
If you dont know how to open the effect settings (gui per effect), look in the fx drop down list and click the cob icon next to the effect (shows on hover)
As mentioned the Echo has several settings, including HP LP Filter
(and if its just echo you are after, worth taking at look at the Echo Out effect as alternative)
geposted Sat 20 Mar 21 @ 9:52 pm
