Hi,
I'm using a DDJ-SX2 with VDJ.
I've put the equalizer control to "Stems".
I use the 5 knobs of channel 4 to control the stems of channel 2.
When I turn all of the 5 knobs to the left there's still a little bit of "Instru".
To check it, I put the pads to stems and I can see "instru" is not turning off when I turn the "gain" knob of channel 4. All the other one stems are working.
It does it on both channel 1 and 2.
Any idea?
Any idea?
geposted Tue 23 Mar 21 @ 6:28 am
Check the "stems bleed" settings, either through the Stems Pad mode (in Virtual DJ), or in the VDJ settings.
geposted Sun 28 Mar 21 @ 1:20 pm
I can see the bleed infos in VDJ but how does it interfere ?
For example, when I turn the "vocal" knob all the way to the left, I can see the vocal stem pad to stop blinking, meaning the vocal is muted.
It doesn't do that with "instru".
geposted Tue 01 Jun 21 @ 1:45 pm
Hi,
I still have the problem.
When I use the pads to mute and unmute the stems it works.
When I use the knobs of deck 1 or 4, only the vocals don't mute completely.
geposted Sat 02 Apr 22 @ 9:03 am
