Topic: Rane 12 dvs... or not
good afternoon
back to vdj... my current set up is denon 1850 mixer with a pair of Rane 12's mk2.
How do i get my 12"s in dvs mode?
Possible or not?
thanks for your help
Ron AKA Dj Reff
geposted Tue 23 Mar 21 @ 4:35 pm
Just hold the "HOLD FOR DVS" button a few seconds, then click it again to select "VirtualDJ DVS" and let the screen turn off.
Of course you need to setup VirtualDJ to use timecode.
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/timecode.html
Keep in mind that in DVS mode the DVS signal from Rane 12 MKII is coming out from it's analog connectors and you need to connect them to a DVS capable sound interface or mixer.
Also in case you're wondering, the signal they will output is detected as "VirtualDJ 8 CD"
Thank's for the info
Will give it a go
