Hi Guys. I'm struggling with using Vdj with my prime 4. I am not getting any display on the prime 4 screen. I have the latest OS etc, can anyone help? thanks in advance.
geposted Sun 28 Mar 21 @ 7:35 pm
See here for the setup, need to set the controller in computer mode:
https://virtualdj.com/manuals/hardware/denon/prime4/setup.html
And make sure you install the Prime 4 Screens from the extensions (should be automatically so)
geposted Sun 28 Mar 21 @ 8:02 pm
Prime screen (Denon SDK) wont work on Arm Mac, but you can try running VDJ with Rosetta
geposted Sun 28 Mar 21 @ 8:39 pm
If its M1, as mentioned run with Rosetta should do the trick.
See here how to start apps with Rosetta https://beebom.com/force-apps-to-run-with-rosetta-m1-mac/
geposted Sun 28 Mar 21 @ 10:46 pm
