Hi
Does anybody know how to use the Virtual DJ DMX pads to control certain Lighting scenes in Soundswitch. For example i want to keep the strobe scenes in manual so i can go the DMX pads in Virtual DJ and select strobe and my lights will strobe or Blackout or i can a to a static colour.
geposted Thu 01 Apr 21 @ 8:36 pm
geposted Thu 01 Apr 21 @ 9:04 pm
And generally speaking you call the name of the button in the DMX software via the pads in VirtualDJ
See here : https://virtualdj.com/wiki/OS2LDMX.html
https://virtualdj.com/wiki/os2l.html
(guide made for Sunlite etc, but logic should be similar hopefully.. SoundSwitch differs a bit, so might have to setup via cue points in the Soundswitch end instead. )
geposted Thu 01 Apr 21 @ 9:06 pm
OS2L is not completely integrated in SoundSwitch, so os2l_ commands wont work/do anything in SoundSwtich.
In other words, you cant control SW using VDJ pads or other actions.
geposted Thu 01 Apr 21 @ 9:20 pm
Ahh Right Will there be any support for Soundswitch in the future?
geposted Fri 02 Apr 21 @ 9:20 am
Not up to us. Better ask SW if OS2L will be fully implemented.
geposted Fri 02 Apr 21 @ 5:45 pm
okay no worries
geposted Wed 07 Apr 21 @ 1:16 pm
