Hi All, In addition to controlling the individual channels on Virtual DJ with the 1850, is there anyway to control the play/cue buttons on Virtual DJ with the 1850? And if so, which buttons to you push on the 1850?
Thanks, Scott
Thanks, Scott
geposted Thu 08 Apr 21 @ 11:54 pm
It is a mixer not a controller
geposted Fri 09 Apr 21 @ 1:19 pm
You could in theory...
But not easy to choose what buttons to map for that perhaps. Mixers that have a pad section would be as easy as adding it to the pads, but the Denon mixer mostly have knobs...
On top of that many of the knobs are hardware knobs evne if they send midi signals that you can map in VirtualDJ. So lets say you mapped the EQ Low to something in VirtualDJ, it would still also act as hardware EQ low on the mixer itself (in hardware)
https://virtualdj.com/manuals/hardware/denon/x1850/controls.html
Doesnt look like there are much "free" buttons to use that are not also hardware
If you dont want to get decks, you could consider a small add-on controller with pads, where the pads can easily be play, pause, sync, cues etc etc (pretty much "anything" simply by changing pads page)
https://virtualdj.com/products/hardware.html?category=addon
geposted Fri 09 Apr 21 @ 1:26 pm
Thank you very much RUNE for your helpful detailed post, I really appreciate it!
geposted Fri 09 Apr 21 @ 6:13 pm
