I noticed that my sampler isn't playing my drops all the way through, but stops before the end, is there a setting that is causing this ?, using the latest vdj 2021. Thanks.
geposted Fri 09 Apr 21 @ 1:39 pm
The drops set as loop perhaps?
Open them in the Samper Editor, and see there
https://virtualdj.com/manuals/virtualdj/editors/sampleeditor.html
geposted Fri 09 Apr 21 @ 1:49 pm
Check that, they are all set to drop / flat in sample editor.
geposted Fri 09 Apr 21 @ 2:54 pm
Odd,.... check at the far right in the waveform in the Sampler Editor.
Should be an end marker (blue line). Perhaps its not all the way to end?
If it is all the way to end, perhaps something happened when you created the sample? recorded a loop that didnt catch the full length you intended .. not sure
geposted Fri 09 Apr 21 @ 3:21 pm
The blue start and end line is at the start and end in the sample editor. The other thing which is a little from the norm is im playing files using isrepeat ? nothing : sampler_volume_master 65% & sampler_play_stutter "T:\RandSample\5DFyffe.mp3"
geposted Fri 09 Apr 21 @ 6:15 pm
ah you are playing sample hardcoded to file path.... the sample editor wouldnt matter then ..
You are playing a file from path...
But other than that, not immediately clear why it wouldnt play whole file
Does it work on deck? And could try add the sample to a bank, and simply drop the file path at end (change for sample slot number. sampler_play_stutter 4 ... for slot for ...etc)
geposted Fri 09 Apr 21 @ 7:04 pm
I loaded the same drop on deck and on the sample pad , both work fine, but if I use the hard code file name , it play to approx 60% and stop.
geposted Fri 09 Apr 21 @ 11:25 pm
