I use a DDJSZ and have an older macbook pro that will only update to high sierra, that is what i use for a back up. I also just bought a new macbook pro and it has big sur. Have there been any issues with compatibility with either of these OS's? The goal is to use the a/b switch on the DDJSZ and be able to go back in forth between high sierra and big sur. Thank you in advance!
geposted Mon 12 Apr 21 @ 11:56 pm
AFAIK there are no compatibility issues with SZ and Big Sur.
Just be sure to install the latest drivers for SZ for each OS. (Each one needs different drivers)
geposted Tue 13 Apr 21 @ 7:21 am
