I think I'm way behind here
But I just realized that I think the "fade out, cut in" Automix option isn't there anymore (image below of the option that I mean)
Is that true? Or am I missing something?
I used to use that option quite a bit...
EDIT: Found it - it's not there when using dual deck mode :-)
geposted Tue 13 Apr 21 @ 7:27 am
It's still present here on latest build...
geposted Tue 13 Apr 21 @ 7:30 am
Just found it
- it looks like it's not there when using dual deck mode (which I never usually do except for testing purposes)
Thanks
geposted Tue 13 Apr 21 @ 7:32 am
