I can't find anything about how to togle sliders in controllers options.
What I have is only one word: level in my slider "Action" window.
When I move my slider up the volume is going down. Same with oposite dirrection, when I move slider down the volume is going up :/
Any chance to change this behavior?
THX!
THX!
geposted Wed 14 Apr 21 @ 1:44 pm
likely you have an invert switch for your faders somewhere on your device, if not
param_invert & level
geposted Wed 14 Apr 21 @ 1:55 pm
Oh!
Found solution a minute ago in YT: "Virtual DJ 8: Invert Pitch Slider" on Echo Papa channel.
Thank You for quick answer
geposted Wed 14 Apr 21 @ 2:12 pm
Uuuu...
Found another issue connected with volume sliders.
Now my sliders are transparent till I move them to the original position.
https://i.imgur.com/nCRe6I5.png
If I move only one slider, it's ok. But when I move them in the same time they are going transparent.
geposted Wed 14 Apr 21 @ 2:27 pm
open settings and tell me the build number found in the bottom left corner.
Also what hardware.
Also what hardware.
geposted Wed 14 Apr 21 @ 2:39 pm
b8.3 b5281
Hercules DJ Console MK1
Looks like 10 yo hardware.
geposted Wed 14 Apr 21 @ 2:46 pm
Made video about my issue:
https://i.imgur.com/pZEtHuy.mp4
geposted Wed 14 Apr 21 @ 2:56 pm
search takeover in settings, set to instant.
geposted Wed 14 Apr 21 @ 3:03 pm
Works!
I want to thank you for your time and help!
https://i.imgur.com/oELRHi2.png
geposted Wed 14 Apr 21 @ 3:19 pm
