of course only 64bit version is affected, everything working in 32bit
This is an hidden initialisation error in case of initial video window would open in a virtual/network display and some 3rd GPU
VDJ 64bit blindly fails and do not open video engine
Same config with original video window in GPU1 or GPU2 opens ok
then moving window to third/Virtual GPU driven display is OK
Going fullscreen brakes everything again for all GPU until moving closing and reopening wingow in GPU1 or GPU2
windowed mode in fullscreen size (or any other size bigger and smaller) is not affected
Tested with intel+nVidia+Spacedesk as well as with Intel+nVidiaQuadro+AMD RX570
Spacedesk or AMD as 3rd GPU does the same (quadro being 2nd and special grid enabled is not affected and can workaround by duplicating pseudo display)
Note that datronic.de (spacedesk) are aware about this issues with some softwares initialization:
"Applications not working in full screen mode on spacedesk display monitor:
Various DirectX games (e.g. Witcher 2, Project Cars, Asseto Corsa, Battlefield, etc.)"
Would be fine to fix in VDJ in a way not to appear there
(video wall with VDJ are great, but 64bit can't be used... easily)
geposted Thu 15 Apr 21 @ 7:52 am
