I notice about 10 tracks from last nights gig didn't save in history.
If memory serves me correctly....this has something to do with fader settings.
Unfortunately I can't figure out the correct settings.
Thanks for your help.
geposted Sat 17 Apr 21 @ 11:37 pm
What setup are you using? controller or analog mixer?
And if controller, using the crossfader or volume fader only?
either way though, the history should save.. defaults to 40 seconds played songs, so if you play shorter than that you can change in settings
geposted Sun 18 Apr 21 @ 10:29 am
I use a Pioneer S11. Only use crossfader to switch between videos and time to log is 30 seconds.
Many times I play audio only and forget about the crossfader. Would that cause it?
I have 6 tracks that I know I played that didn't log. Not the end of the world but this was a banger night night and would like to save for future use.
Could it be a database?
geposted Mon 19 Apr 21 @ 3:17 pm
