Topic: Ask the dj notification
Is there a way to get a pop up or notification when someone uses Ask the dj? also when reply to a message is sent what is the easiest way to see reply without having to go into another screen to find it?
geposted Mon 19 Apr 21 @ 5:10 pm
The way I use to see reply is a to clone AskTheDJ folder in a sideview tab
the sideview becomes a message scroll panel
Is there any easy way to add that side folder? or anyway you can DM me a guide how to add it?
Just drag and drop ;-)
I don't remember where I found this, but this works perfectly for me.:
get_askthedj_unread ? blink 300ms : param_equal `get_browsed_folder` "Ask the DJ" ? goto_last_folder : browser_gotofolder "askthedj://"
Still Works Perfectly :)
