Is there a setting that will fix mp3 broken links automatically
geposted Mon 19 Apr 21 @ 9:04 pm
if its broken its broken..
VirtualDJ will auto attempt to fix, but if unsuccessfull you need to locate manually
Right-click and choose "relocate file"
Btw, before you do that, try add new location where the songs are now, so that its part of the database, and VirtualDJ has a chance to auto fix. Right click music folder(s) and choose "Batch=> add to search db"
You can also remove all missing files in one go, if you prefer that.
At the far left browser toolbar, find remove missing at the small radio option dot there
geposted Mon 19 Apr 21 @ 10:07 pm
