I have a Pioneer DDJ-SB3 controller. Mike plugs in on the back. I'm running Virtual DJ on a new Macbook. I hear myself in my headphones and on the speakers. But when I go to broadcast, you don't hear it in the stream at all, and I'm broadcasting through Virtual DJ into Mixcloud. In the audio panel, I can't adjust the volume or turn it on. In the audio settings, I can set up a mike input, but none of the options in the drop down menu work (FYI-I use Blackhole as my multi output device). And I don't have the option to set it up as a output, assuming that's what I'm supposed to do. Everything else is working great. Pics attached for reference.
What am I doing wrong? Help!
geposted Fri 23 Apr 21 @ 2:29 am
The SB3 sends the m8c input dorectly to the master out. It doesn't send it to the laptop. So it can't be recorded or broadcasted
geposted Fri 23 Apr 21 @ 5:25 am
You would need to loop back the audio to a line in at the computer to be able to broadcast/record the mic on that controller
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Fri 23 Apr 21 @ 9:03 am
