I'm suddenly being prompted to connect to vdj on startup of program and cannot connect or close
the prompt as I do not always want or need to connect. This connection prompt just recently started
out of nowhere. Now my system says vdj is not responding to windows and calling it AppHangB1.
I haven't a clue. This connection prompt has hijacked vdj and I cant close it, connect or get around it.
Any theories out there?
geposted Sat 24 Apr 21 @ 11:09 am
You need to connect (aka login) to activate the license...
Its a one time thing, and should not show again after that..
There is even a "remember" option at bottom of that window
geposted Sat 24 Apr 21 @ 11:30 am
Thank you. I cant connect or login at all. Vdj freezes. It doesn't matter what connection or login option I choose
it just freezes and windows closes it. Frustrating.
geposted Sat 24 Apr 21 @ 11:45 am
Well after using an older verson last weekend due to this and 20 attempts this morning vdj finally allowed me to
login and now I'm functional again. Now I'm nervous. If I don't have an internet connection am I now going to be
locked out? Hopefully this is a one time deal as you say. I'm going to try and turn off my wifi and startup with no
connection to vdj and see. Thank you...
geposted Sat 24 Apr 21 @ 11:49 am
You should never have to login again (unless you login at more computers, then the first one will invalidate)
But you can use 2 computers just fine
geposted Sat 24 Apr 21 @ 12:03 pm
