I have noticed lately the audio isn't in sync, the music is playing slower. My latency is set at 288. Should I lower it or raise it higher.
geposted Wed 28 Apr 21 @ 12:06 pm
288 is very low..
So the latency might be elsewhere..
How is your audio output routed ? Bluetooth, to an external amp? etc etc
And if on Windows using Asio, the latency setting is at the brands driver utility settings
geposted Wed 28 Apr 21 @ 12:27 pm
And if using multiple sound cards or speakers "far" way, you might notice a difference in headphones vs speakers.. if the cards are not same, they might have different latency, and output delays
geposted Wed 28 Apr 21 @ 12:34 pm
