Hello everybody.
I am connecting a DJJ-1000 to VJ PRO 2021.
(Everything works fine with rekordbox).
When I turn on VJ, the console identifies me, but, here the first doubt, tells me that I have to move the selector of line 3 (the first on the left) to USB A.
If I don't, I have to do it later ...
Continuing, it forces me to use deck 1 (on line 3) and deck 2 (on line 1), it also shifts me by one channel the channels of the console's BEAT FX.
I would like to work, as it should be, on line 1 and line 2. But it only goes on line
I think it's some setting / setting, but I can't find it.
Who helps me?
Thanks
Who helps me?
Thanks
geposted Wed 28 Apr 21 @ 1:49 pm
Open Config, click on Mappers icon, then click on DDJ-1000 on top.
On the deck assignment drop down menu on the right choose 1,2,3,4
Finally (or if the unit is already in 1,2,3,4 deck assignment) click on options icon and type "mixerorder" on the search box on top. Set the mixerorder setting to 3124
geposted Wed 28 Apr 21 @ 6:21 pm
