I just organized and saved all playlists and set the compatibility mode to CDJ-2000NXS.
The CDJ reads the playlists/folders but displays as empty. The songs are there since I can find and load them by search for track. Any advice?
Also, how are you guys unplugging the flash drive? just removing or ejecting? not sure if there is a button that kind of prepares the flash drive. Thank you :)
geposted Fri 30 Apr 21 @ 5:44 am
Is it only the playlists that are empty, or are the tracks also not shown if you browse by album/artist/... ?
geposted Fri 30 Apr 21 @ 6:23 am
